'Performance Proms' , also TPS enhancer snake oil, and other chip basics
Old 05-04-2002, 03:34 PM
Drew ATX's Avatar
TPS enhancer with a performance prom
I was wondering about something. I've been planning on getting the TPIS tps sensor enhancer for my car. But I've also ben planning on getting a prom from Jet or Hypertech. It's my understanding that the tps enhancer signals the computer at 60% throttle that I've got it at WOT. My question is, will a performance prom do the same thing or not? Would I be waisting my money buying both?
Old 05-04-2002, 03:47 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You're wasting your money on both. Thje TPS enhancer is useless snake oil, big deal it brings the TPS up faster, that doesn't do anything special in the computer except maybe a little more pump shot (yawn)
As for a junk chip like hypertech or jet, instead buy the stuff to burn your own. You can duplicate what is in those for under $200, and have the potential to keep doing it as you learn more. But even if you just burn one chip you could beat jet, hypercrap, et al.
Old 05-04-2002, 03:49 PM
Drew ATX's Avatar
Do you really think I could do better myself? I really have no idea what I would be doing. I'd be learning through trial and error.
Old 05-04-2002, 03:57 PM
Ed Maher's Avatar
Car: 04 GTO
Thats just it. When i first got into PROM burning i happened to get a jet 305 chip for my car from a guy i knew. And i compared it to my stock chip. The ONLY differences were these:
- The torque converter clutch lock-up speed was raised to 40mph
- the timing table had a few numbers changed, just raising timing in a few spots.
As a matter of fact, i'll show you what i'm talking about, be back in a second.
Old 05-04-2002, 04:14 PM
Ed Maher's Avatar
Car: 04 GTO
Here is a screenshot of tunercat, chip editing software. This is the stock main spark table for a 90-92 TPI 305:
And here is a comparison with a the 'performance' Jet chip:
the -1.8 means that the stock chip has 1.8' less timing than the jet chip. As you can see, all they did was add a few degrees of timing in the high load (high MAP values)
Anybody can do that, you can basically duplicate the effect without even buying PROM burning equipment just by turning the distributor except that works everywhere not just at WOT.
But yes, it really is as easy as changing a row of numbers in a 'spreadsheet' to duplicate a chip you'd spend hundreds for. The only difference is, you can then keep changing it as you learn more, and experiement to find best performance.
As for me, i tried running the Jet chip and my car ran like crap and pinged all the time. It was adding way too much timing at high RPMs. So i made a chip with less timing in the high RPMs and more timing in the low RPMs and i had a lot more pick-up off the line and it didn't ping
edit: well while it's here i might as well explain the table in case it isn't obvious to some. Like i said, it's the main spark table. Across the top are MAP values, which is like the opposite of vacuum. High MAP means low vacuum (high load, WOT, etc), and low MAP is high vacuum (idle, cruise). A typical stock L98 cammed 305 engine idles around 40kPa (18" vacuum) or so. Anyhow, down the side is RPMs. The number in front of you is how much timing the ECM sends to the distributor at those loads and RPMs.
If you're used to old style carb and vacuum advance distributor cars this should make sense to you if you look at it as the numbers across the top are like the vacuum advance, you can see that there is less timing at low vacuum, and more timing at high vacuum. And the numbers going down are your mechanical advance, adding timing as the RPMs go up. An important advantage here though is you can easily put in exactly the right timing at every rpms if you want to, squeezing every last HP out of it. Or you can just run a more traditional curve just as easily.
To get your total timing, these values are added to the initial timing in the distributor, and there is also another timing adder in the ECM for WOT.
WOT in the ECM is called PE or power enrichment. Think of PE like the secondaries of a carb, with an added shot of timing as well)
Speaking of which, WOT turns on around 50-70% throttle, which is why those TPS foolers are junk. There is no benefit in turning on PE a fraction of a second earlier, and once you're in PE, thats it, 80% throttle or 100% throttle the computer adds the same timing and fuel
The following 2 users liked this post by Ed Maher:
Joe3831990 (07-17-2023), jredelk (01-01-2020)
Old 05-05-2002, 12:13 AM
Drew ATX's Avatar
Wow! Thanks for all the help bro. :hail: I'm going to take your advice and just make my own chip. Thanks again for taking the time to post all of that and explain it.
Old 05-05-2002, 09:42 AM
Ed Maher's Avatar
Car: 04 GTO
NP. We've been preaching about how poor these off the shelf chips are for a while now, but it never occurred to me to actually show exactly how little change there really is in there. And not only is there just those small timing changes, but in my experience those changes were exactly wrong for my application. If i had bought that jet chip as a performance replacement it would have gone into the trash it pinged so bad.
Since i've already been packing so much info into this post, here is some more advice to novices, a few basic features of PROM tuning that are easy and make the initial buy in cost well worth it, even if you don't try to be a guru and get heavy into tuning.
- Fan on temps. You can set the temp that each of your fans turn on and off. So this way no matter what thermostat you run you can keep your car cool in traffic in the summer without having to mess with any hard to reach sensors on the engine. Stock the fans come on until 220' or more. If you lower that to about 10' above your thermostat opening temperature you will see a big difference in how well your car can stay cool since it's not so close to overheating. And thats even with a stock 195 thermostat.
- torque converter lock-up points. Not a big issue in L98 cars, but most of the 305 bins i've seen lock up the converter clutch as low as 25mph. This gives you that lugging boggy feeling when driving at low speeds. The L98 cars don't lock the TCC until 40mph or so which is a much more reasonable value. There is also another TCC lock-up parameter that kicks in at WOT but thats a little more advanced of a topic.
- Idle speed vs. coolant. You know how you car idles faster when it's cold, then idles normally once warmed up. This is where you control exactly how fast it idles and at what temps. Those of you who like cold thermostats might be interested in this one, a 160' for example won't even get you to the normal idle speed in some bins. Basically all kinds of enable temps in the bin, but you don't need to play with most of them, but they can come in handy.
- injectors. Want to run high FP, or bigger injectors, no problem. All you do is figure out how much you're changing the relative injector size (for example going to 22s from 19s, you just multiply the injectoor constant by 22/19) or if you're changing pressure, the number you mutiply with is given by this formula squareroot{(new psi^2)/(old psi)^2}
-spark curve. This is the fun part, but you definitely have to be careful. The PROM gurus don't advocate playing with the spark curve until you have your fuel figured out, but most people aren't going to get that heavy into it. Even if you don't touch the fuel though you can find more performance just by tweaking the shape of the spark curve. Juust be careful and only make small changes. And keep track of what you're doing, and how it changed performace (you really need to be at the track or using a g-tech or similar to measure the difference in performance or you might just take yourself into detonation and never know it because of the knock sensor)
IMO the reasons above alone can justify buying the equipment even if you enever touch anything else, especially considering a barebones set-up is cheaper than some off the shelf junk chips anyway.
Now if i can find some free time maybe i'll condense this into a tech article or a sticky post
Old 05-05-2002, 01:32 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
There's more than enough information packed into the PROM forum to get anyone started into PROM burning, IMHO. And it's also more effective use of your dollar. You could buy a 200$ JET chip, which probably won't net you much benefit at all, or you could buy a 150$ pocket programmer, 20$ in spare chips, and have total control over your car.
Spend the extra 30 bucks on beer to drink while you read Trax's prom burning article.
Old 05-05-2002, 01:50 PM
Tuned Port's Avatar
ive browsed the PROM burning forum, and almost none of the topics made sense to me. for a novice, i think you would need a book or something to teach you the basics. and is $150 all you need to burn PROMs? i thought you needed like at least $500 in equipment
Old 05-05-2002, 08:01 PM
86Tra/maro's Avatar
Location: Newark,NJ The state where racing on I 78 rules.
Tunedport,
Your right! I read & re-read the articles on computer tuning it doesnt make much sense to me either. My main problem is what parts do I need to buy to modify all of the above parameters (fuel , spark tables ,fan on/off temp ,Etc...) mention by Ed? A SPECIFIC (combo) of parts # of what to buy from a person who has been modifying his/hers eprom. For instance if ED uses pocket programmer, a particular program modifier, connection cables ??( i guess that what its called ) , & any other ED specific COMBO of parts would be a great help. Newbie programmers Have no idea of what combo of parts to BUY! U expert or experienced programmers made a very big list of most of the parts that can be bought. But as I said earlier, It would be greatly appreciated to help the NEW Guy make the right choice the first time around.
When I looked at the TunerCat software I was really surprised at all the different "smaller" programs that they were selling at $20.00 a piece ! I had no idea of what to buy! I was about to purchase all of the smaller programs but before i did i asked a question like: How can i buy all of these programs , cables ,eraser, chips ,etc... for $250.00?? Thats what I mean NEW PEOPLE DO NOT KNOW THE COMBO OF PARTS TO modify all of the timing ,fuel, fan on/off,ETC..
Hope I make sense.
njdaewoo
:hail: :hail:
Old 05-05-2002, 09:16 PM
Ed Maher's Avatar
Car: 04 GTO
Since this is meant as an introduction thread, no heads will be cut here so long as you make sure you have read the whole thread up to this point, so don't worry about sounding dumb, i want to help people see how easy this all really is. Anyone caught making a wise *** remark in this thread will be shot as well, i want this to be a safehouse so i can figure out what i can do to help people with the basics.
Firstly, Tim (traxion) is in the process of updating the intro to PROM burning article. The 'new' version is http://www.xecu.net/timsiford/update.htm
Read over that, as well as what's below. If this thread clarifies some of what he says, or you see something confusing, post here and i'll talk to tim and see if we can re-work the article some more to make sure it's clear.
Here goes the barebones of what you need to get started...
1- http://www.xtronics.com/memory/EPROM.htm
Pocket Programmer from xtronics, PN I-PP2, $150
- this is what you need to actually burn the chip. Make sure they give you the windows software with it, very easy to use. To burn a chip all you do is load the buffer (like opening a file), hit the program button and when it's done hit verify to re-check to make sure that it wrote properly. To read a chip all you do is hit the move device button to load the chip into the buffer, and from there you save it. Really is that easy.
2- A bin editor program.
Most of us use tunercat to do our work on the chip. Total cost including the TDF (a file that tells the tuner software where the tables are in the chip) is $90.
If you are confused on what to get, all you need is the 'Tuner' software ($70) and the TDF $20) for your ECM and year (more on this later). All those other little programs are completely seperate and unnecessary unless you are VERY advanced.
There are also free editors, which do work quite well (they were mostly written and organized by theoriginal DIY guys), they just aren't as nice and polished as tunercat. But if you just want to change a few numbers and don't need every little feature then these will work fine for you. There are 2 major free programs, WinBin and GMEPRO
I'm not sure what and where the latest and best versions are to download so i'd rather defer this to someone who can point the way for sure. I do know you can find ECU files (like the TDF for tunercat, except for winbin) @ ftp://ftp.diy-efi.org/incoming/ as well as many other places. I'm sure the information is on the PROM board, but i don't have the time to sift through search results looking for links right now, sorry.
3- You need chips and a way to put them into the ECM.
As for chips, at this point, flash chips are the way to go since they don't require any erase time. These will be PN 29C256-12PC or 29C256-90PC, the only difference being the speed of the chip which doesn't matter sinc ethey are both fast enoiugh for our ECMs, the slower -12s being $1 cheaper or so. You can get these at www.jdr.com, just put the PN into the search window to find them. a few of these are all you need.
As for putting them in the ECM, there are a couple ways of doing this. Rather than beat type too much, i'll just defer to Tim's article here. In the how you do it section he describes the various methods people are suing to put their chips onto the stock memcal (thats the name of the whole blue 'chip' in the car, the actual chip sits on that. Unfortunately Tim's picture links are dead but i'm sure that will be remedied soon.
As for the ZIF sockets he mentions, you can also get them from www.jdr.com, just type in ZIF in the search, and you need the 28 pin style. I mention JDR for both these elctronics just because i have found they are usually in stock for these items we need. These can be purchased anywhere you can buy real electronics though as Trax mentions in the article.
And thats it. All you NEED to buy is a burner ($150) some chips and a ZIF socket (~$25). The free software (wWinBin or GMEPro) is more than capable of filling any novices needs. And as for putting the chip in the car, you do take a risk if you unsolder the stock chip to put a ZIF on it. It can be done, and is certainly cheaper than buying a spare memcal, but keep in mind you might need to buy a spare should things go horribly bad (this isn't really different than most other car work though, i mean if you're porting an intake and you cut through you need to get it welded or geta new intake right, same thing here and a new memcal from GM is only ~ $50) Making or buying an adapter (such as craig moates http://ice.prohosting.com/moates/gmecm/hardware.htm has been selling, as well as 29c256 chips and ZIF sockets) is a safer and easier alternative, but then you're spending a little more money. You can also find these adapters on ebay from old jet chips (thats where i got the jet chip from, i'm using the adapter from it.) and also stock memcals to modify cheap as well.
Clear as mud?
Old 05-05-2002, 09:58 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Here's an example of one man's burning equipment. =) I've started with this setup and it's taken me as far as I've ever wanted to go.
Pocket programmer from www.xronics.com. $150
ZIF adapter and eproms from Craig Moates ~$60
A cable for reading data from the car ~$95
(forgot where I got the cable from)
Tunercat ~$90
Now you can build the data cable yourself for around 20-30$, and you can get free software to get the price down.
When I unsoldered my stock chip from the memcal, I destroyed the chip (not the memcal), so be careful for that. I bought a spare memcal for $45 from acdirect and keep it in the car just in case.
I didn't understand too much of what I was looking at the first time I edited chips either, and it can be overwhelming the first time. But I did find all the info off the PROM board and the diy-efi mailing list archives. The rest was experimentation.
And to quote Grumpy: Always document your changes!
Old 05-06-2002, 12:45 PM
BlazinOR's Avatar
Well done Ed !
Ed, you should be commended for putting this up, and with a sticky. Thank you, this along with Glenn M's input has reignited my desire to get into the PROM burning arena.
Old 05-06-2002, 12:52 PM
Ed Maher's Avatar
Car: 04 GTO
I threw this up as a sticky because i know most of the true novices are intimidated by the PROM board. Like i said above, i figured this would make a good safe-house to clear out the beginner questions so that hopefully such clarification can be built into the intro to PROM article.
I also thought it was important to actually show how little you are getting for your money when you buy one of the junk off the shelf pieces. Hearing over and over again that htey are junk is one thing, but i think actually seeing exactly what we have seen really drives home the point of how big of a waste it is.
Old 05-06-2002, 02:54 PM
86Tra/maro's Avatar
Thanx Ed,
U really opened my eyes as a newbie to the programming deal! Like I said before I had no idea of what combo to buy. That was my main problem but now I have a real starting point.
My new question is can my same laptop be used as a portable scanner?
Thanx again ED & Synapsis!
Old 05-06-2002, 03:14 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I've seen Pentium 90 laptops with 16 megs of ram run Craig Moates' software with no problems. I use a 500 Mhz Dell with 128 megs of ram and Datamaster in the car. I also burn my chips with it at the track.
Old 05-07-2002, 01:10 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
its true guys reading that stuff gets a little overwhelming, but if a particular topic makes no sense do a little research on it, a lot of these guys have been doing it a long time and refering to different things by the various names are like us that stick to this TPI board are used to some more basic things that you didnt understand when you first got your car, before you owned a TPI set up did you know what MAF or SD or ECM meant? or how to adjust your fuel pressure with an AFPR or even for that matter how to make your stock FPR adjustable? nope most of us didnt, and all those guys are just as willing to help, as long as your question isnt "hey how do I burn a chip" if its more along the lines of, "Im still learning, please explain" then they will usually jump right in, but they arent as fast to respond it seems as a lot of the guys here on the TPI board, you would think so since they are sitting at their computer tuning their cars! haha j/k Im still learning and this summer will break into the piggy bank and get all the goodies to get going myself.
Synapsis, whats the extra cable for?
Old 05-07-2002, 01:49 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
It's the serial to ALDL cable to plug the computer (laptop) into the diagnostic port on the car to make it a scanner. The cable is based off the MAX232 circuit if you want to search and get the schematic. I believe I got it from AKM electronics, but don't quote me on that, it's been awhile. The cable is cheaper than a refurbished AutoXray, and the software you can use with it is a lot better as well.
Old 05-07-2002, 08:05 PM
wataru's Avatar
I've been thinking of getting into prom burning since I found this site. I've read through Trax's introduction to prom buring and there are still a few questions I have. If anyone can help I would appreciate it.
#1 What is a definition file? Traxion said you can buy them for
$20 from Tunercat but does'nt really say what they are or maybe I misunderstood what he was talking about?
#2 He says that its only gonna be about $250 for the equipment but then at the end of the article goes into the fact that your really gonna need a scanner. Well thats an additonal $150 right their, and thats for the "cheap" hand held units that only read 1 data point /sec. My question is. Are the hand held units sufficient or do you really need to purchase a laptop and software and cable, ect. to take full advantage of prom buring?
Please keep in mind that I am really new at this .
Thanks!! Barrett
Old 05-07-2002, 08:22 PM
Bort62's Avatar
Good Questions.
The Definition File, If I understand it properly ( and thats a big IF ) is what tells Tunercat wich ECM Your trying to edit.
So, You need the Definition file to match the ECM you wanna Write.
As for needing a scanner, all You need is a Cheapo Laptop and Craig Moates software ( free ).
Much better than any of those hand help scanners, the only thing that really compares is Diacom, But thats $$$
And, If all you want to do is simple flag changes and stuff, you Don't need a Scanner. Not right away anyhow.
Hope that helps.
Old 05-07-2002, 08:27 PM
wataru's Avatar
Doh . Thats right I remeber reading about it now. I did'nt realize thats what you call it.
Thanks for the help.
Later Barrett
Old 05-07-2002, 09:29 PM
monte-ss's Avatar
does it have to be a laptop? I have an old computer and with a long enough cable and something to roll it around on shouldnt be a problem? just wondering, besides I have an auto xray (thanks to the generouse company of checker )
Old 05-07-2002, 09:50 PM
Bort62's Avatar
Well, a Long cable and a Computer on a roller Cart would be great for in the driveway testing... but To get the full use out of a scanner, you really need to drive around with it logging data.
So Unless you have a Roller in your garage to Simulate load, the Desktop won't do you Much Good.
Old 05-07-2002, 10:09 PM
monte-ss's Avatar
True, didnt think of that, unless I hadmiles and miles of cable!! or a generator in the trunk of the car,,,,, hmmmmmmmmmmmmm hehe:sillylol: guess Ill just stick to the Xray for now
Old 05-08-2002, 01:00 AM
Bort62's Avatar
You could prolly sell the Xray to a local guy, and buy an old laptop for the price.
You will get much more detailed information.
Old 05-08-2002, 08:52 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Alot of people recommend Craig's software and I have previewed it. It looks nice. My question is no one seems to comment on the Freescan software form Andy. Is it ok I downloaded it and so far I like it. I haven't been able to use either on my car because I am still waiting on a cable. Will Craig's software and Freescan both use the same cable?
Old 05-08-2002, 12:07 PM
Ed Maher's Avatar
Car: 04 GTO
AFAIK moates software uses the same cable as freescan.
Another thing i failed to mention in this post earlier is that some of the TPI cars did come with a speed limiter. This is also a 1 number change, very simple to do, yet another easy advantage for the novice.
Old 05-08-2002, 12:53 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Any pitfalls involved with using Freescan. I like the GUI interface. If there is I would like to know before I start modifying my settings based on the information this program produces.
Old 05-10-2002, 08:59 PM
DM91RS's Avatar
Car: 91 RS
I wondered if anyone was going to mention that. The speed limiter was the first mod I did.
The compare feature on Tunercat that Ed is showing is also a very good feature to show what changes you have made as you edit chips. And TC has very good support. At least for me
Good thread Ed. I may have to spend more time on this forum
Old 05-11-2002, 11:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: TPS enhancer with a performance prom
You need to read thru your editor and see what's going on. Better yet, get a commented hac of your Mask, and really understand things. Again this is why folks need to get together and develope some commented hacs.
There is more to it then just meeting the PE enables.
You also need to understand what is going on in PE.
On some cals there is a correction for PE Fuel based on TPS so that at various TPS settings there are some enrichments, and enleanments. In some cals they use a delta TPS, meaning How Much the TPS changes in a given amount of time does certain things.
You're also seemingly confusing WOT with PE.
Old 05-11-2002, 11:26 PM
monte-ss's Avatar
grumpy slow down a little were still learning, whats PE?
Old 05-12-2002, 04:21 AM
DM91RS's Avatar
Car: 91 RS
Power Enrichment
Old 05-12-2002, 08:38 AM
Ed Maher's Avatar
Car: 04 GTO
I tend to agree. Not that grumpy isn't a foont for great esoeric knowledge, the purpose of this post is meant as a much lower level covering these concepts so as to make people realize all the great easy stuff they have access to in PROM burning.
While the stuff grumpy talks about is true, the skinny of it boils down to you're not going to find a single person with a TPI f-body with a TPS 'enhancer' that they thought was worthwhile, and especially nobody with a fast TPI f-body running one.
Old 05-12-2002, 09:59 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i know you guys say the TPS enhancer doesnt work, and i believe the money could be spent elsewhere, but i bought one a few months ago and tried it at the track in my almost stock Corvette. Here are my mph results : 1st run (left things alone) - 101.05.... 2nd run (added enhancer) - 101.82.... 3rd run (bumped fuel pressure from 48 to 50 psi) - 101.93. the peice did add some mph to my trap speed, indicating it increased hp.
Old 05-14-2002, 12:25 AM
dejaybrian's Avatar
if you dont want to burn your own chips...these guys will burn one for you according to your specs of your car, and your mods and all that...
www.superchips.com
engine is stronger all around...you can really tell the difference, and it doesn replace the prom itself...its a module that hooks up to the prom?? check it out...its way cheaper than hyperjunk and the like
Old 05-14-2002, 12:59 AM
Bort62's Avatar
I hardly think that .77 mph between two individual runs is Sufficent to prove anything. Most bracket racers would Kill for that kinda consistancy.
Besides, in a 1/4 blast the TPS enhancer Really dosent do anything because you spend the whole time in PE normally. The only thing it can Claim to Do is put you In PE earlir in pedal travel wich dosen really do much good cause if your wanting to go fast... just push the pedal that much further.
Unless you like to race at part throttle.
Old 05-14-2002, 11:23 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
I have even got it to run successfully on a friggin 286!!!! Tested that just out of curiosity.... But it worked!!!
Old 05-14-2002, 11:34 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Craig's software is sweet in that it'll run on *anything*. He makes good chip adapters too.
I'm currently working on plugging my TI-83 Plus SE calculator into the ALDL to take data/monitor the engine. It'd be a cheap alternative to an AutoXRay and would give a lot more info. I'm having a hell of a time reading serial data off the Graphlink cable, though. =/
Old 05-14-2002, 11:41 AM
Bort62's Avatar
LOL
:lala: NERD!:lala:
Old 05-14-2002, 12:05 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
LOL
Hey, I had to buy that thing for my college math class. My laptop belongs to my company, so I need something to monitor my car with when I don't have it.
I write data acquisition/machine control software for a living, this is just like taking my work home.
And I need something to do car related while I save up for my new AFR heads.
Old 05-14-2002, 12:40 PM
Bort62's Avatar
Well if you can get that work, It would be Nice for alot of us )
Altho with the low CPU needs its prolly cheaper to buy a laptop to Run Moates, than a new TI
How about making one for the palm pilot ? hahaha
Use the IR port to send back and forth.
Old 05-14-2002, 12:53 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I think someone already started developing one for the Palm. And I no longer have a PC at home to develop for WinCE. (Fried two motherboards in two months. )
The main reasons for using a TI calculator are a) the calculator is 80 bucks, b) I have one already, and c) it's ready to use immediately. I hate waiting for my laptop to boot so I can take data on a 15 minute trip. With the calculator I can just press 3 buttons and be ready to go in seconds. And it has native support for graphing.
Old 05-14-2002, 01:11 PM
monte-ss's Avatar
hey if it works Id like to know, I have a TI-89 with all the same graphing capabilities plus it has 3d graphing as well.
Old 05-19-2002, 06:14 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I have been using FreeScan with my 749 ECM using $58 code (SyTy) modded to run a TPI. So far I have not had any problems with it and the logs are easy to follow. cheers, Bob
Old 06-02-2002, 09:04 PM
TBIWorks's Avatar
I keep telling myself that I'm going to get into my own prom burning, but I have some other stuff I need to do to my car before I spend the $$$. I would definitly be a novice, but I will be coming to you guys for help. I do need to know how to tell what ECM my car has and if it uses that adapter thing for the prom. I have not pulled the ECM out yet, but is there a way to tell for sure without? It is an '88 GTA built in mid '87 350 TPI single cat, MAF car, automatic of course. ???
Old 06-09-2002, 06:07 PM
monte-ss's Avatar
prom needed
I know your not supposed to go to the prom site and beg for a prom so thats why Im here! haha actually Im trying to figure out a charging problem and Im doing some testing and the VATs system is pulling 4.2 amps with nothing else plugged in, so I would like to eliminate it and see if that cures anything so if anyone has all the stuff to burn one for me, please let me know, I have an 89 IROC set up, all standard settings just want to elim the VATs for now till I can get this problem fixed then move on to getting the stuff to burn my own.
so if anyone can help I would greatly appreciate it.
thanks
Jack
jpotvin@rap.midco.net
Old 06-19-2002, 08:00 AM
streetrunner's Avatar
This sounds too good to be true. So I can go and get approx. $200 worth of stuff and burn my own PROMS. I can keep changing nd testing setups for as long as the hardware works? and i can change my speed limiter, rev limiter, timing at different RPM's, when my fan comes on for juss $200? This is the first tiome i have ever thaught about PROM burning to be a modification that could realy help my cars perfomance. Can u burn all kinds of PROM's with this softwaare of just yours? Can i burn my own and a PROM for a 2002 grand am? This sounds like a very cost efeective modification. Can i program a 305 TBI chip to swap to a TPI? that is somehting im thinkin about doing.
Old 06-26-2002, 08:45 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: prom needed for a fool
You won't be laughing when you get your wallet burned. The reason we STOP people from scabbing eproms is because we've had problems with scum suckers looking for fools wanting cheap eproms.
There is NO WAY a person can write an optimum eprom without hands on testing of your car. Yeah, I can write a "formula" eprom based on specs and it will run okay. But it will be far from optimal. Only with "hands on" access to your car and a great deal of time will your eprom be optimal. No one can afford to pay someone to do that kind of work. The only way is to get the equipment (cheaper than most custom eproms) and do it yourself..plain and simple.
In this world you "get what you pay for". If someone is offering a "custom eprom" for under $100, how good do you think it really is? I can tell you right now, JUNK! Any one that is any good wants at least a couple of hundred dollars because THEY KNOW the real work that will be necessary to get it to run good. So it ends up costing MORE than burning your own.
But be my guess, but I hope you don't get burned from the dozen of vultures just waiting for you!
Old 06-26-2002, 09:06 AM
monte-ss's Avatar
I didnt say anything about an optimum eprom, I just wanted a stock eprom with the vats disabled, I thought at the time it was causing problems but have eliminated it from the list of possible problems
Old 06-26-2002, 09:09 AM
Car: Death Mobile
Engine: 666 c.i.
FYI, the money I save in gas by invoking Highway Mode MORE than paid for all my eprom burning equipment and software in just over a year. From 20-70 MPH (I have a method of recording and graphing the results), my times are .6 secs quicker. And of course, the knowledge I have gained in being able to interpret scan tool readings is priceliss.
All from tuning the eprom.
Quick Reply: 'Performance Proms' , also TPS enhancer snake oil, and other chip basics
