deffinitons...sticky??
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
okay i tried to come up w/ a idea for deffining all the flags, tables, constants etc. to make a sticky about a week ago. but the more reading i do the more i realize how in depth some of it would have to go which would take much time and space, and even some gurus have trouble getting some parts. so i decided to go this route instead these are deffinitions for abb. i have run across while studing articles and stickies trying to learn how to tune (since im a total newb) feel free to add more or deffine the few i left blank and i will edit this regularly. thanks
John
SA = spark advance
wot = wide open throttle
PE = power enrichment
Map = Manifold absolute pressure
esc = electronic spark control
est = electronic spark timing
vss = vehicle speed sensor
tdc = top dead center
btdc = before top dead center
atdc = after top dead center
aldl = assembly line diagnostic link
IAT = intake air temp.
IAC = idle air control
TPS = throttle position sensor
BLM = block learn multiplier (long term fuel trim)
tsa = total spark advance
K/S = knock sensor
DFCO = deceleration fuel cut off
C/L or CL = closed loop
O/L or OL = open loop
Egr = exaust gas recirculation
TCC = torque convertor clutch
AE = acceleration enrichment
VE = volumetric efficency
Kpa = kilo-pascals (metric measure of pressure for map)
DE = deceleration enleanment
AFR = air to fuel ratio
PCV = possitive crankcase ventilation
Baro = biometric pressure
CCP = charcoal canister purge
INT = integrator (short term fuel trim)
bpw = base pulse width
bpc = base pulse constant
msec = milli second .001 seconds
usec = micro second .000001 seconds
nsec = nano second .000000001 seconds
pph = pounds per hour
gps = grams per second
bsfc = brake specific fuel consumption
DC = Duty Cycle
mat = manifold air temperature
adc = analog to digital conversion?
s/d map = speed density map?
VATS = vehicle anti-theft system
mvdc = milli volts dc
TF = throttle follower
~T = inverse temperature?
~AFR = inverse afr?
CLT = closed loop correction term
since im a newb somthing like this is probably the biggest contribution i can make right to the prom board but its worth it cause im sure it may help at least one person.
John
SA = spark advance
K/S = knock sensor
DC = Duty Cycle
~AFR = inverse afr?
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
Here are a couple more...
DC = Duty Cycle
~AFR = inverse afr?
DC = Duty Cycle
~AFR = inverse afr?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
You might find a few more here:
http://www.diy-efi.org/gmecm/faq/biglist.txt
Also, "hyst" = hysteresis.
Car: 87 T/A
I know it's a bit off topic, but I have a favorite:
TLA = three-letter acronym
Car: 91 Red Sled
A/C Air Conditioning
A/D Analog to Digital
ABS Anti-Lock Brake System
ADC Analog to Digital Converter
AE Acceleration Enrichment
Aero Aerodynamic(s)
AFCO All Fuel Cut Off
AFPR Adjustable FPR
AFR Air Fuel Ration
ALDL Assembly Line Diagnostic Link
ALPHA-N Form of EFI
BBC Big Block Chevy
BDC Bottom Dead Center
BIN Binary
BLM Block Learn Multiplier
BP Barometric Pressure
BPW Base Pulse Width
CAFÉ Corporate Average Fuel Economy
CAN Controller Area Network
CARB Carburetor. (Also California Air Resources Board)
CAT Catalytic Converter
CC Combustion Chamber
CCC Computer Controlled CARB
CDI Capacitive Discharge Ignition
CE Check Engine
CFI CrossFire Injection
CL Closed Loop
CNP Coil Near Plug
CPU Central Processing Unit
CTS Coolant Temp Sensor
DAC Digital Analog Converter
DC Duty Cycle
DE Deceleration Enleanment
DFCO Deceleration Fuel Cut-Off
DIY Do It Yourself
ECM Engine Control Module
ECT Engine Coolant Temperature
ECU Electronic Control Unit
EEPROM Electronically EPROM
EFI Electronic Fuel Injection
EGO Exhaust Gas Oxygen
EGR Exhaust Gas Recirculation
EGT Exhaust Gas Temperature
EPROM Erasable PROM
ESC Electronic Spark Control
EST Electronic Spark Timing
F/A or A/F Fuel-Air Ratio
FEEPROM Flash EEPROM
FP Fuel Pump
FPR Fuel Pressure Regulator
GM General Motors
GN Grand National
HEGO Heated EGO
HEI Heigh Energy Ignition
HW HighWay
IAC Idle Air Control or Intake Air Control
IAT Intake Air Temp
IC Injector Constant
INT Integrator
KS Knock Sensor
Lean AFR greater than Stoich
LT Long Tubes
LTC Long Term Correction
MAF Mass Air Flow
MAP Manifold Absolute Pressure or Manifold Air Pressure
MAT Manifold Air Temperature
MIL Malfunction Indicator Lamp
MPFI MultiPort Fuel Injection
NB Narrow Band
NETRES Network of Resistors
O2 Oxygen
OBD-I On-Board Diagnostics pre-95
OBD-II On-Board Diagnostics post-95 pre CAN
OEM Original Equipment Manufacturer
OL Open Loop
PA3 Peripheral Address # but with GM it's the Knock Counter
PCM Powertrain Control Module
PE Power Enrichment
PFI Port Fuel Injection
PIC Programmable Integrated Circuit
PROM Programmable ROM
PW Pulse Width
PWM Pulse Width Modulated
RESNET Resistor Network
Rich AFR less than Stoich
ROM Read Only Memory
SA Spark Advance
SAE Society of Automotive Engineers
SBC Small Block Chevy
SD Speed Density
SES Service Engine Soon
SFI Sequential multiport Fuel Injection
STC Short Term Correction
Stoich Stoichiometry
TBI Throttle Body Injection
TCC Torque Converter Clutch
TDC Top Dead Center
TDC Top Dead Center
TGO ThirdGen.Org
TPI Tuned Port Intake
TPS Throttle Position Sensor
VAFPR Vacuum referenced ADFP
VE Volumetric Efficiency
VS Vehicle Speed
VSS Vehicle Speed Sensor
WB Wide Band
WOT Wide Open Throttle
Aero Aerodynamic(s)
AFPR Adjustable FPR
AFR Air Fuel Ration
ALPHA-N Form of EFI
BBC Big Block Chevy
BIN Binary
CE Check Engine
CL Closed Loop
CNP Coil Near Plug
DC Duty Cycle
DIY Do It Yourself
EPROM Erasable PROM
FP Fuel Pump
GM General Motors
GN Grand National
HEGO Heated EGO
HW HighWay
IAT Intake Air Temp
INT Integrator
KS Knock Sensor
LT Long Tubes
MAF Mass Air Flow
NB Narrow Band
O2 Oxygen
OL Open Loop
PE Power Enrichment
PW Pulse Width
SA Spark Advance
SD Speed Density
TDC Top Dead Center
TDC Top Dead Center
TGO ThirdGen.Org
VS Vehicle Speed
WB Wide Band
Car: 1995 K1500 Yukon 2-Dr and 1982 Z-28
Engine: truck: 350hp 454 car: 485hp 355
Transmission: truck:5spd car: Doug Nash 5spd
Axle/Gears: truck: stock car: Dana44 w 3:23
Re: definitons...sticky??
you guys left out a couple that we all use at some point in learning how to tune:
SNAFU- Situation Normal All Fouled Up
FUBAR- Fouled up Beyond All Repair
maybe "fouled" isnt quite strong enough...
Car: 87 GTA, 91 Nissan 300ZX 2+2
Engine: 5.7L, 6 banger NA
Transmission: 700R4, Auto
Axle/Gears: 3.27 Posi, no idea
old thread but i thought of a couple ones that come to mind often at work
RTFM = read the f'ing manual
ID10T error condition
RJMcEachern
RJMcEachern
