FOR ANYONE ASKING ABOUT CORVETTE WHEELS
1 Post
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
I keep seeing threads popping up asking what it takes to make C6 wheels fit mainly. I'll shed any info I know to hopefully at least reduce a few of these threads from showing up.
For regular C5/C5Z/C6 sizes (NOT C6Z06/ZR1), they should fit with nothing more than a 2" adapter, and some people run an 1/8" shim up front, although it's not necessary. With a 4th gen rear, no adapters are needed on the rear. This goes for all 17/18/19 versions of the wheels mentioned above.
As far as C6Z06/C6ZR1 (factory sizes/offsets, not replicas) wheels go, I have no experience with those personally, and anyone I've seen running them have swapped rear ends/minitubbed their car. I've done a small amount of research with no success, so if anyone has info on these that they would be glad to shed out, I'll be happy to change this post with your name on it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: FOR ANYONE ASKING ABOUT CORVETTE WHEELS
I agree with you a lot of threads been coming up
Got info from skulte website
![Name: 2014-05-13%2008.18.10_zpshq4rhjoj.png
Size: 194.9 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/336022d1501309631-anyone-asking-about-corvette-2014-05-13-2008.18.10_zpshq4rhjoj.png)
Using a 4th Gen Rear
If you've changed your third-gen rear to a 4th gen rear, you do not need adapters. The 4th gen rear is approximately 2" wider per side. This is the same as using a set of 2" bolt on adapters
Any corvette wheel that are 12" in width your going to need inner wheel well work , how much depends on how fat of tire you want and tuckage
Rear tire size choices
335 width tire going to need a mini tub
305-315 width tire need minor inner fender work with hammer and maybe some cutting if you like on 11" wide wheel , on a 12" wide wheel going to need alot more work depending on how tucked you want them but most than certainly needs alot off metal work not a bolt up and go deal
295 width tire on 11" wide needs very little work
Running front big brake kit ! Just fyi
Also if your running big brake kit like ls1 Or c5 you can run a
1.75 " adapter due to .3" increase in front track on each side IIRC you can still use 2" adapter
For brembo setup with 1le hub it pushes front track .6"
So you can run a 1.5" adapter
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
![](http://i1248.photobucket.com/albums/hh481/zachary_james3/2014-05-13%2008.18.10_zpshq4rhjoj.png)
I run 1.75" front adapters on 18x8.5 c6 wheels, along with c5 brakes. 2" could work fine to. I ran 1.75's before c5 brakes as well and still fit fine
The rear 19x10's in 79 mm offset would require a 2.5" spacer! I run 4th gen rear and still need a .625" hubcentric slip on spacer. 2.5-2.625" would be ideal for thirdgens!
Engine: 305 to 350
Axle/Gears: 10 Bolt
It depends on how much tuckage you want but it does make a slight difference
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I run 295 on 11 not a corvette wheel but needed light work I may try 305 when I get a chance
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
Ok guys I read all these posts and just want to make sure. These are the wheels I'm looking at off ebay. Will these fit my 3rd gen Z28 with the right spacers? I don't want the wheels sticking out or rubbing either. My Z is also lowered on Hotchkis springs. Offsets are 56mm front / 79mm rears. Here's the description. Any help would be great. Thanks in advance.
These are the Centennial cup wheels :
This listing comes with (2) - 18x8.5 and (2) - 19x10.0 for a total of 4 wheels
WILL NOT FIT 2005-2013 , Z06, ZR1 OR GRAND SPORT
C6 SIZES AVAILABLE IN SATIN BLACK, GLOSS BLACK, AND CHROME ALSO!! PLEASE SEE OTHER LISTINGS.
OFFSETS 56/79MM
OFFSETS 56/79MM
Engine: 305 to 350
Axle/Gears: 10 Bolt
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
Yeah I did read it but I'm not a very technical guy so therefore I am asking for confirmation just to make sure. That's all. Then with all the other posts and numbers I'm starting to get confused. Don't need the sarcasm. If I knew 100% I wouldn't have to ask so please excuse me for not fully understanding.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Back spacing and or wheel offset are what important any corvette wheel on stock thirdgen is a standard 2" as you can see on far right column
19x10 rear - 79mm - 2.25" Rear
18x8.5 front. - 56mm - 2" front
Like stated above 4th gen rear is 2" wider on each side
And big brake upgrade up front
Also like stated above you can gain more clearance from inner wheel well in the rear if you want more tuckage
Cool, thanks for clarifying for me. Appreciate it.
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
So the idea is, correct me if I'm wrong, you take the backspacing of the corvette wheel, subtract the offset, and then subtract the size of the spacer you are using. This should get you no more than 5" in the front, and 5.6" (IIRC) in the back, which are the maximum backspacings possible on a stock thirdgen.
Car: RS(RIP) 90 IROCZ,89GTA 02 Firehawk
Engine: 5.0 LB9 305,5.7 L98 350 5.7 LS1 346
Transmission: 700r4 & T-56
Axle/Gears: 2:73, 3:27 & 3:73
Thanks really helped. I had some 12" in mind but now thinking of going a different route.
But what if I swap to a 4th gen rear end same thing still needs inner fender work?
Engine: 305 to 350
Axle/Gears: 10 Bolt
Doesn't matter still need inner wheel well work
like stated above aanything wider than 11" wheel and anything larger than a 295 tire
All that changes is that you dont need adapters in the reae
1 Post
Car: 1985 Trans Am
Engine: 385
This makes me wonder what the offset is on the factory 18x10 C6 wheels are (NON z06)? Unless I'm just that plain stupid, I didn't see it listed on the chart, but I'd imagine it would be the same as the 19x10s. If that is the case, anything more than the 2" spacers that I currently use would stick the tire clear out of the fender. It meets up perfect right now, and I have plenty of room left on the inside fender well for a 295 if money would allow.
Its not. The 18's are not the same as 19's. the 19's for some reason have a high offset at 79mm. Most 18 x 9.5-10.5 vette wheels are 54-56 mm. Thats about an inch different.
2.5 will tuck the 19. If you could get a 2.625" that may be even better. Regular 2" spacers work fine for 9.5 and 10.5" 17-18 wheels.
I have the 4th gen rear and a .625" spacer to get my c6 19x10 wheels off the inner well and just inside the lip. Perfect fit and 4th gens are 1.875-2" wider depending how you measure
Engine: 305 to 350
Axle/Gears: 10 Bolt
From my understanding is that non z06 had higher offset due to fact of not having wide body compared to zo6 for more tuckage with tire which retracts wheel 20 mm I believe as zo6 doesn't have same issue due to wider fenders which are about tad over 1.60" wider on each side I believe hence why c6 zo6 wheels have lower offset and is also wider I think 12" wide wheel here is straight comparison of wheel specs
C6 non Z06
Front 18 x 8.5, +56 mm offset
Rear 19 x 10, +79 mm offset
C6 Z06
front: 18 inch x 9.5 inch, +40 offset
rear: 19 inch x 12 inch, +59 offset
C6 non Z06
C6 Z06
Engine: 305 to 350
Axle/Gears: 10 Bolt
More detailed wheel specs to include C7
17" × 8.5" +56 88-96 frt/rear97-04 frt
17" × 9.5" +54 88-96 frt/rear, 97-04 frt
17" × 11" +36 90-95 ZR1 rear
17" × 11" +50 96 Grand Sport rear
18" × 8.5" +56 88-96 frt/rear, 97-13 frt exc. C6 Z06, ZR1, Grand Sport
18" × 9.5" +40 84-87 frt/rear, 06-13 Z06 & Grand Sport frt
18" × 9.5" +57 97-04 rear, 05-13 frt
18" × 10.5" +58 97-04 rear
19" × 10" +40 06-13 C6 Z06, ZR1 & Grand Sport frt, 427 Convertible frt
19" × 10" +56 97-04 rear
19" × 10" +79 05-12 rear
19" × 11" +64 97-04 rear
19" × 11" +79 05-13 rear
19" × 12" +59 06-13 C6 Z06 & Grand Sport
20" × 12" +59 06-13 C6 Z06, ZR1 & Grand Sport rear, 427 Convertible rear
2014 C7 Stingray
Front: 18" x 8.5" with 245/40/18
Rear: 19" x 10" with 285/35/19
Offset are same as standard C6
2014 C7 Coupe with Z51 Performance Package
Front: 19" x 8.5" with 245/35/19
Rear: 20" x 10" with 285/30/20
Same offsets as standard C6
If any info is off let me know
2014 C7 Stingray
Engine: 305 to 350
Axle/Gears: 10 Bolt
A Historic Look Back at the Wheels that Vettes Ride On!
1953-1967
http://www.corvettereport.com/corvet...967/#more-2936
1968-1996
http://www.corvettereport.com/corvet...-1968-to-1996/
1997-2009
http://www.corvettereport.com/corvet...009/#more-3287
Old links I saved awhile ago thought I share pretty cool
1953-1967
1968-1996
1997-2009
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
2014 C7 Stingray
2014 C7 Stingray
Would those tires go on with no problems for the c7 and z51 package or would it mess up the speedometer? Just asking.
1 Post
Car: 1985 Trans Am
Engine: 385
In all honesty, I don't really worry about it. One because our speedometers don't read high enough anyway, two because mine has 3:70 gears, and three because my speedometer cable broke
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I agree
I don't really mess with the speedo I try to stay as close to stock tire height as possible but if your taller no harm no foul I drive with flow of traffic or faster so it doesn't matter to me lol very minimal complaint vs the looks and performance gains from wider tires, especially running atleast 9.5 upfront makes a big difference
In short your speedo will read higher or lower depending on tire height and in no way or fashion will it damage anything , unless your running low rider wheels than your trans will get mess up lol
And honestly I think thirdgens look better with a taller tire anyways it fills the wheel well alot better
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
before i make another thread, just want to get yalls opinion on these before i buy em..
Engine: 305 to 350
Axle/Gears: 10 Bolt
I wouldn't be surprised if majority of those adapters came from one source and sold at different price points
You can go wrong with the ones you posted
I prefer wheel and hub centric the one you posted is just hub centric
I've had ebay adapters they did the job and will do so for majority of people but there imported from China and aluminum is probably a lower quality and no warranty of some sort and fitment was ok but not perfect over all just wasn't happen and didn't feel confident about them
Me persinally i went after much research spent alittle more and got adapters from motorsport tech I personally prefer them and fitment was 100 times better also and less vibration , aluminum was definitely higher quality I believe 6061t6 billet aluminum and there cut using cnc machines also lifetime warranty a bit more more but saftey is very high in my list
But that's my opinion so others will think other wise and dont think it's worth it, so it's up to I'm sure you be happy with whatever decision you make
Car: '90 Camaro
Engine: 305 tbi
do you have links or part number from the place you got yours, still looking for the right set.
Engine: 305 to 350
Axle/Gears: 10 Bolt
https://www.motorsport-tech.com/wheel_adapters.html
Call them they often have returns at discount prices
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Zach,
I noticed a few errors in your list at the top of the thread.
1) 84 to 87 coupes came with 8.5" wheels standard, convertibles had 9.5" for whatever weird reason. Could be wrong, but this is what I have seen and heard.
2) If the early C4 16" x 9.5" wheel really has a 6.6" BS, you would need a 1.5" spacer to fit, otherwise it would stick out 0.5" past the wheel well.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Zach,
2) 8.5 had + 32 offset and 9.5 had +38, but I also heard offset range from 36 - 38 mm
All in all seems to be wacky lol
http://www.corvetteactioncenter.com/...usp_chart.html
You would need 1.5 spacer
1 Post
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
I am upgrading to C5 Z06 brakes on the front this weekend (from Scott at www.bigbrakeupgrade.com). They're actually on the FedEx truck to be delivered today! Excited! Anyways, I also have a new set of 2.00" adapters to use in place of the 2.25" ones because of the added track width the brake upgrade adds.
YMMV, however, with my current factory brakes, the distance between my wheels and the tie rod ends is barely 1/4", so I'm glad I bought what I did. This problem likely would not exist with 18"/19"/20" wheels, because the larger radius causes the rim to be further from the tie rod (and other components).
Hope this helps....
1 Post
Car: 1985 Trans Am
Engine: 385
Being perfectly honest, I myself run a 2" spacer with a .25" shim, not for clearance, but to bring the tire out to the edge of the fender.
1 Post
Car: 1985 Trans Am
Engine: 385
And by the way to anyone who wants to click the link, it's NSFW!
Edit: Fredj87 seems to be a spam bot. All of his posts contain that same link.
Drone358
12-10-2015 08:16 PM
84 TA NV
09-06-2015 08:02 PM
