1991 700r4 won't go into park UPDATE: got park but NOTHING else
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, well my 700r4 transmission will not go into park. I've even gone underneath and disconnected the shifter linkage and tried moving the little "arm" into park myself, but reverse is as far as it'll go, so I know it's not a shift linkage issue. What's going on?
Last edited by musclecar70sfan; 06-20-2011 at 10:06 AM. Reason: grammar... really tired lol
Engine: LB9
Re: 1991 700r4 won't go into park
UPDATE: Well this morning I had another go at it. Turns out I was low on trans fluid, so I topped it off and took a hammer and GENTLY tapped the transmission itself in different spots, hoping that would jar something loose. It did, I got park back, but now it's refusing to pop into anything else, meaning reverse, and all forward gears aren't coming in. And I can only move the selector in 2 spots, park, and reverse, although reverse just feels like the pawl is only disengaging because I tried starting the car in that position and it just rolled like it was in neutral. Is it time for a T5 swap boys?
Car: F250,83 diesel, many more
Transmission: 4R100, 700R-4
Axle/Gears: 3.73, 3.42
The roller on the detent inside of the transmission may have broke. You can pull the pan and take a look at it. If it is it is an easy fix with the pan off.
Rob
Rob
Engine: LB9
Do I dare just reassemble it, pour in some fluid and hope it continues to work?
And I forgot to mentioned that I had to roll the car a few feet a couple days ago. When the selector was in "reverse" (which acted like neutral) it would click as it moved. This was before I dropped the pan.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
