G=Force T-5 case
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
G=Force T-5 case
Thought I would share....
This is their HD case.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: G=Force T-5 case
happen to have a stock one for a side by side comparison? its looks pretty
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well that should solve the case flex problem, that's super beefy. Might have to downgrade from the t-56 lol.
Right? Just wonder what other issues might arise from strengthening the case. Puts more stress probably on the primary/secondary shafts? Anyone use stock internals with this case, beat on the car and still have good results? Lol @ the downgrade...
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I am wondering this myself. I have to wonder what kind of results would occur from this. I sold my t5 complete out of my Camaro, and I kind of wish I hadn't now just to try this out. Whatever I guess.
Car: '88 Camaro (Gone...)
These have been out for a while, they offer it as an option if you have them rebuild your transmission.
Wish I'd sprung for that option at this point, oh well
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Just curios and so others will know, What part of the stock case does the flexing? they both look stout.
You see the two holes in the case on each end, one on top of the other? Those are for the mainshaft and cluster shaft.
The gears on these shafts are helical cut, which is great because they aren't noisy. However, helical cut gears will try to force each other apart, "push" away from each other so to speak when they are under load. The greater the load, the harder they force each other apart.
If there is enough force, they will begin to spread apart and reach a point where the teeth on the gears are not meshed sufficiently with each other, resulting in stripped teeth and breakage.
If you can visualize that, you can see how the case flexes under load, in such a way that the shafts are not held rigidly in mesh with each other. You can also see why third gear is the most common gear failure occurs in
--Also don't forget that the torque arm is attached to the tailshaft of the transmission, this is another contributor to the case flexing. I'm a firm believer in the benefits of relocating the torque arm mount to the crossmember or the driveshaft tunnel if you are going to abuse it and want it to live
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
And if you have a noisy 3rd gear, get ready to fix things.
Bought mine with a noisy 3rd gear, and drove it with a noisy 3rd gear for a good 5 years but when it does fail, its not fun.
Got stuck in 4th and had to drive home like that, which you may think is hard to start off in 4th, that was childs play as when it got stuck in 5th and I had to drive home like that was the real fun drive. And yes you can start off in 5th gear with about a block of starting room, and a dozen or so bump n stalls, till your rolling enough to chug along in 5th.
Don- What internals are you going to be running in you HD case? when can we expect an update?
Thanks-
Eric
Thanks-
Eric
any updates for us on the G-force Case?
It's the regular G-force gear set. $1000 I think.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
camaro, case, cut, diystraightcutgeart5rebuild, force, ford, gears, gforce, gm, reviews, straight, strengthening, t5, transmission, users
